Installing the Out-Front Mount
NOTE: If you do not have this mount, you can skip this task.
  1. Select a secure location to mount the Edge® device where it does not interfere with the safe operation of your bike.
  2. Use the hex key to remove the screw Callout number 1 from the handlebar connector Callout number 2.
    Out-front mount with callouts
  3. Place the rubber pad around the handlebar:
    • If the handlebar diameter is 25.4 mm or 26 mm, use the thicker pad.
    • If the handlebar diameter is 31.8 mm, use the thinner pad.
    • If the handlebar diameter is 35 mm, do not use a rubber pad.
  4. Place the handlebar connector around the rubber pad.
  5. Replace and tighten the screw.
    NOTE: Garmin® recommends tightening the screw so the mount is secure, with a maximum torque specification of 7 lbf-in. (0.8 N-m). You should check the tightness of the screw periodically.
  6. Align the tabs on the back of the Edge device with the bike mount notches Callout number 3.
    Out-front mount with a callout
  7. Press down slightly and turn the Edge device clockwise until it locks into place.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
