Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Select Menu > Settings > System > Widget Management.
  2. Select a widget to add or remove it from the widget loop.
  3. Select Reorder to change the location of a widget in the widget loop.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
