Segment Options
Select Menu > Training > Segments > Segment Options.
Turn Guidance
Enables or disables turn prompts.
Auto Select Effort
Enables or disables automatic goal adjustment based on your current performance.
Search
Allows you to search for saved segments by name.
Enable/Disable
Enables or disables the segments currently loaded on the device.
Default Leader Priority
Allows you to select the order for goal targets while racing a segment.
Delete
Allows you to delete all or multiple saved segments from the device.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
