Using Cycling Dynamics
Before you can use cycling dynamics, you must pair the power meter with your device using ANT‍+® technology (Pairing Your Wireless Sensors).
NOTE: Recording cycling dynamics uses additional device memory.
  1. Go for a ride.
  2. Scroll to the cycling dynamics screen to view your power phase data Callout number 1, total power Callout number 2, and platform center offset Callout number 3.
    Cycling dynamics data with callouts
  3. If necessary, select Data Fields to change a data field (Adding a Data Screen).
    NOTE: The two data fields at the bottom of the screen Callout number 4 can be customized.
You can send the ride to the Garmin Connect™ app to view additional cycling dynamics data (Sending Your Ride to Garmin Connect).
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
