My phone will not connect to the device
If your phone will not connect to the device, you can try these tips.
  • Turn off your smartphone and your device, and turn them back on again.
  • Enable Bluetooth® technology on your smartphone.
  • Update the Garmin Connect™ app to the latest version.
  • Remove your device from the Garmin Connect app and the Bluetooth settings on your smartphone to retry the pairing process.
  • If you bought a new smartphone, remove your device from the Garmin Connect app on the smartphone you intend to stop using.
  • Bring your smartphone within 10 m (33 ft.) of the device.
  • On your smartphone, open the Garmin Connect app, select Menu symbol or Menu symbol, and select Garmin Devices > Add Device to enter pairing mode.
  • Select Menu > Settings > Connected Features > Phone > Pair Smartphone.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
