Using the Backlight
You can select any key to turn on the backlight.
NOTE: You can adjust the backlight timeout (Display Settings).
  1. Select Menu > Settings > System > Display.
  2. Select an option:
    • To allow the device to automatically adjust the brightness based on the ambient light, enable Auto Brightness.
    • To manually adjust the brightness, disable Auto Brightness, select Brightness, and select Up arrow symbol or Down arrow symbol.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
