Updating Your Activity Profile
You can customize ten activity profiles. You can customize your settings and data fields for a particular activity or trip.
  1. Select Menu > Settings > Activity Profiles.
  2. Select an option:
    • Select a profile.
    • Select Create New to add or copy a profile.
  3. If necessary, edit the name and color for the profile.
  4. Select an option:
    • Select Data Screens to customize the data screens and data fields (Adding a Data Screen).
    • Select Default Ride Type to set the type of ride that is typical for this activity profile, such as commuting.
      TIP: After a ride that is not typical, you can manually update the ride type. Accurate ride type data is important for creating bike friendly courses.
    • Select Segments to turn on your enabled segments (Enabling Segments).
    • Select ClimbPro to enable the ClimbPro feature (Using ClimbPro).
    • Select Alerts to customize your training alerts (Alerts).
    • Select Auto Features > Auto Lap to set how laps are triggered (Marking Laps by Position).
    • Select Auto Features > Auto Sleep to automatically enter sleep mode after five minutes of inactivity (Using Auto Sleep).
    • Select Auto Features > Auto Pause to change when the activity timer automatically pauses (Using Auto Pause).
    • Select Auto Features > Auto Scroll to customize the display of the training data screens when the activity timer is running (Using Auto Scroll).
    • Select Timer Start Mode to customize how the device detects the start of a ride and automatically starts the activity timer (Starting the Timer Automatically).
    • Select Nutrition/Hydration to enable food and drink consumption tracking.
    • Select MTB/CX > Grit/Flow/Jump Recording to enable grit, flow, and jump recording.
    • Select Navigation > Map to customize the map settings (Map Settings).
    • Select Navigation > Routing to customize the routing settings (Route Settings).
    • Select Navigation > Navigation Prompts to show navigation messages using a map view or text prompt.
    • Select Navigation > Sharp Bend Warnings to enable navigation warning messages for difficult turns.
    • Select GPS Mode to turn off GPS (Training Indoors) or change the satellite setting (Changing the Satellite Setting).
    All changes are saved to the activity profile.
GUID-AF71A516-A97E-4CE9-BD88-68921B5F014D v7
August 2024
