Recording a Swim Activity NOTE: Heart rate data is not displayed while swimming. You can view heart rate data in the saved activity in the Garmin Connect™ app. Press to view the menu. Select > . Select a pool size. Select . Double-tap the touchscreen to start the activity timer. The device records activity data only while the activity timer is running. Start your activity. The device displays your distance and swim intervals, or pool lengths. After you complete your activity, double-tap the touchscreen to stop the activity timer. Select an option: Select to save the activity. Select > to delete the activity. Select to resume the activity. Child Topics:Setting Swim AlertsParent Topic: Training
Recording a Swim Activity NOTE: Heart rate data is not displayed while swimming. You can view heart rate data in the saved activity in the Garmin Connect™ app. Press to view the menu. Select > . Select a pool size. Select . Double-tap the touchscreen to start the activity timer. The device records activity data only while the activity timer is running. Start your activity. The device displays your distance and swim intervals, or pool lengths. After you complete your activity, double-tap the touchscreen to stop the activity timer. Select an option: Select to save the activity. Select > to delete the activity. Select to resume the activity. Child Topics:Setting Swim AlertsParent Topic: TrainingHomeTrainingRecording a Swim Activity
