Using the Stopwatch Press to view the menu. Select > . Double-tap the touchscreen to start the timer. Double-tap the touchscreen to stop the timer. If necessary, select to reset the timer. Parent Topic: Clocks
Using the Stopwatch Press to view the menu. Select > . Double-tap the touchscreen to start the timer. Double-tap the touchscreen to stop the timer. If necessary, select to reset the timer. Parent Topic: ClocksHomeClocksUsing the Stopwatch
