Improving Calorie Accuracy
The watch displays an estimate of your total calories burned for the current day. You can improve the accuracy of this estimate by walking briskly or running outside for 15 minutes.
  1. Swipe to view the calories widget.
  2. Select Calibrate calories symbol.
    NOTE: Calibrate calories symbol appears when calories need to be calibrated. This calibration process only needs to be completed one time. If you have already recorded a timed walk or run, Calibrate calories symbol may not appear.
  3. Follow the on-screen instructions.
Copyright © Garmin. All rights reserved.GUID-4205DB9F-0ACD-4AC2-86A8-957F27150AE4 v3
