Calibrating the Treadmill Distance
To record more accurate distances for your treadmill runs, you can calibrate the treadmill distance after you run at least 1.5 km (1 mi.) on a treadmill. If you use different treadmills, you can manually calibrate the treadmill distance on each treadmill or after each run.
- Start a treadmill activity (Recording a Timed Activity).
- Run on the treadmill until your Lily® watch records at least 1.5 km (1 mi.).
After you complete your run, select
- Check the treadmill display for the distance traveled.
Select an option:
To calibrate the first time, tap the touchscreen and enter the treadmill distance on your watch.
To manually calibrate after the first-time calibration, select
, and enter the treadmill distance on your watch.
Parent Topic: Training
