Getting Your VO2 Max. Estimate
The watch requires wrist-based heart rate data and a timed 15 minute brisk walk or run to display your VO2 max. estimate.
  1. Press Touch button symbol to view the menu.
  2. Select Settings symbol > V02 max. symbol.
    If you have already recorded a 15 minute brisk walk or run, your VO2 max. estimate may appear. The watch updates your VO2 max. estimate each time you complete a timed walk or run.
  3. Follow the on-screen instructions to get your VO2 max. estimate.
    A message appears when the test is complete.
  4. To manually start a VO2 max. test to get an updated estimate, tap your current reading and follow the instructions.
    The watch will update with your new VO2 max. estimate.
GUID-4205DB9F-0ACD-4AC2-86A8-957F27150AE4 v4
November 2023
