Reviewing Tracks You can review tracks that you have previously recorded. From the main menu, select > Apps > Tracks. Select a track, and select . The track appears on the map with the recorded statistics about the track. If necessary, select to change the track shading. Parent Topic: Tracks
Reviewing Tracks You can review tracks that you have previously recorded. From the main menu, select > Apps > Tracks. Select a track, and select . The track appears on the map with the recorded statistics about the track. If necessary, select to change the track shading. Parent Topic: TracksHomeOff-Road Navigation FeaturesTracksReviewing Tracks
