Connecting the Device to Vehicle Power
You should always confirm all electrical connections are secure and will not come loose while operating the device.
If the ignition wire is not used, do not tie the ignition to the positive terminal on the vehicle battery. Ground the ignition wire or leave it disconnected. Failure to ground or disconnect the ignition wire when the ignition is not used could prevent the device from powering on.
Parent Topic: Connections
