Using the Map
You can use the map to navigate a route (Your Route on the Map) or to view a map of your surroundings when no route is active.
- Select Chase Map.
- Touch anywhere on the map.
Select an option:
To pan left, right, up, or down, drag the map.
To add or remove map layers such as topographic and BirdsEye imagery, select
To zoom in or out, select
or
To switch between map views, select
To start a route, select a location on the map, and select Go! (Starting a Route by Using the Map).
