Adding a Location to Your Route
Before you can add a location to your route, you must be navigating a route (Starting a Route).
You can add locations to the middle or end of your route. For example, you can add a fuel station as the next destination in your route.
  1. From the map, select Back to previous page > Apps > Apps > Search.
  2. Search for a location.
  3. Select a location.
  4. Select Go!.
  5. Select an option:
    • To add the location as the next destination in your route, select Add as Next Stop.
    • To add the location to the end of your route, select Add as Last Stop.
    • To add the location and edit the order of destinations in your route, select Add to Active Route.
The device re-calculates the route to include the added location and guides you to the destinations in order.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
