External Antenna Mounting Considerations
You can install the external antennas on your vehicle to get the most accurate position data for your navigation device. For best performance, consider these guidelines when selecting the antenna mounting location.
NOTE:
External antennas are included only with the
Tread® XL - Baja Race Edition device.
To ensure the best reception, you should mount the antennas in a location that has a clear, unobstructed view of the sky in all directions.
You should not mount the antennas near the engine or other sources of electromagnetic interference (EMI).
You must mount the antennas at least 5 cm (2 in.) apart from each other.
Parent Topic: Installing the Tread XL - Baja Race Edition Device
