Tread XL Dock Overview
The Tread® XL Dock accessory securely holds your device while you travel over rough terrain. Before you can use the dock features, you must install the dock and connect it to vehicle power.
Press down to secure the navigation device in the dock. |
Slide the switch toward the latch to lock the navigation device in the dock. |
Connect to vehicle power using the included power cable. |
Connect to an optional Group Ride accessory. |
Connect to an external Iridium antenna. |
Connect to an external GNSS antenna. |
Press to turn on the navigation device. |
Press to zoom out the map. |
Press to zoom in the map. |
Press to move through menu items or scroll the map. |
Press to return to the previous screen. |
Press to select an option. |
Press to open the map. |
Press to open the Team Tracking map tool. |
Press to save a waypoint. |
