Tread Audio Box Specifications
General
Weight
997 g (2.2 lbs.)
Water resistance
IEC 60529 IPX7 (water), IEC 60529 IP6X (dust)1
Operating temperature range
From -20 to 70°C (from -4 to 158°F)
Storage temperature range
From -40 to 85°C (from -40 to 185°F)
Input voltage
From 8 to 14.4 Vdc
Current (max.)
40 A
Current (muted)
less than 650 mA
ANT® wireless range
Up to 3 m (10 ft.)
Compass-safe distance
203 mm (8 in.)
Fuse
15 A mini-blade type
Bluetooth® wireless range
Up to 10 m (30 ft.)
On-board, Class D Amplifier
Output power per channel
4 x 100 W RMS at 14.4 Vdc input, 4 ohm, 10% THD2
Line output level (max.)
6.0 V (peak to peak)
Aux input level (typical)
1 V (RMS)
Tuner
FM radio frequency range
87.5 to 107.9 MHz
FM frequency step
200 kHz
AM radio frequency range
530 to 1710 kHz
AM frequency step
10 kHz
1 The device withstands incidental exposure to water of up to 1 m for up to 30 min, and is protected against powerful jets of water. For more information, go to www.garmin.com/waterrating.
2 The stereo may limit the output power to prevent the amplifier from overheating, and to maintain the audio dynamics.
GUID-B3443908-7800-44A1-BE1E-0D780C075CBA v3
August 2023
