Port Identification
![Device connector view with callouts](../Shared/GUID-94946FB4-39D9-45EA-B000-4CB5E9942850-high.jpg)
Item |
Description |
FUSE |
Contains the 15 A fuse for the LED outputs. |
Not used. |
Connects the device to the auxiliary in and line/subwoofer out wiring harness. |
Connects the device to the ground terminal wire (GND). |
Connects the device to the +12V terminal wire. |
Connects the device to the AM/FM antenna. |
Connects the device to the speaker wiring harness. |
Connects the device to the LED wiring harness. |
Connects the device to an optional USB accessory. |
Parent Topic: Connections
