Mounting Considerations
You can flush mount the device in the dashboard, or bail mount the device on the dashboard.
When selecting a mounting location, observe these considerations.
You must select a location that is strong enough to support the weight of the dock and the device.
You must select a location that allows room for the routing and connection of all of the cables.
You should mount the device to provide an optimal viewing angle as you operate your vehicle.
Parent Topic: Installing the Tread XL - Baja Race Edition Device
