Activity Tracking
For more information about activity tracking accuracy, go to garmin.com/ataccuracy.
My step count does not seem accurate
If your step count does not seem accurate, you can try these tips.
  • Wear the watch on your non-dominant wrist.
  • Carry the watch in your pocket when pushing a stroller or lawn mower.
  • Carry the watch in your pocket when actively using your hands or arms only.
    NOTE: The watch may interpret some repetitive motions, such as washing dishes, folding laundry, or clapping your hands, as steps.
The floors climbed amount does not seem accurate
Your watch uses an internal barometer to measure elevation changes as you climb floors. A floor climbed is equal to 3 m (10 ft.).
  • Locate the small barometer holes on the back of the watch, near the charging contacts, and clean the area around the charging contacts.
    The barometer performance may be affected if the barometer holes are obstructed. You can rinse the watch with water to clean the area.
    After cleaning, allow the watch to dry completely.
  • Avoid holding handrails or skipping steps while climbing stairs.
  • In windy environments, cover the watch with your sleeve or jacket as strong gusts can cause erratic readings.
GUID-9CC4A873-E034-4A06-B2E0-636DCFE760EE v7
June 2025
