Manually Syncing Data with Garmin Connect NOTE: You can add options to the controls menu (Customizing the Controls Menu). Hold to view the controls menu. Select Sync. Parent Topic: Garmin Connect
Manually Syncing Data with Garmin Connect NOTE: You can add options to the controls menu (Customizing the Controls Menu). Hold to view the controls menu. Select Sync. Parent Topic: Garmin ConnectHomeConnectivityPhone Apps and Computer ApplicationsGarmin ConnectManually Syncing Data with Garmin Connect
