System Settings
Language and Keyboard Settings
To open the Language and Keyboard settings, from the main menu, select Settings > System.
Voice Language
Sets the language for voice prompts.
Text Language
Sets all on-screen text to the selected language.
NOTE: Changing the text language does not change the language of user-entered data or map data, such as street names.
Keyboard Language
Enables keyboard languages.
Units and Time Settings
To open the Units and Time settings page, from the main menu, select Settings > System.
Current Time
Sets the device time.
Time Format
Allows you to select a 12-hour, 24-hour, or UTC display time.
Units
Sets the unit of measure used for distances.
Position Format
Sets the coordinate format and datum used for geographical coordinates.
Setting the Time
  1. From the main menu, select the time.
  2. Select an option:
    • To set the time automatically using GPS information, select Automatic.
    • To set the time manually, drag the numbers up or down.
Position Format Settings
NOTE: Do not change the position format or the map datum coordinate system unless you are using a map or chart that specifies a different position format.
Select Settings > System > Position Format.
Coordinate Format
Sets the position format for the location information.
Display Format
Sets the format in which coordinates will appear on the device.
Datum
Sets the coordinate system on which the map is structured.
Map Spheroid
Shows the coordinate system the device is using. The default coordinate system is WGS 84.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
