Planning a Route
A route can include many stops and shaping points, and it must include at least a starting location and one destination.
  1. Select Apps icon > Route Planner > Add.
  2. Search or select a location on the map to be the starting point for this route.
  3. If necessary, select a route calculation mode for the route segment.
    TIP: You can select Adventurous routing to let the device automatically calculate the most adventurous route to your next destination (Adventurous Routing).
  4. If the next point along your route is a stop, select Stop. Otherwise, select Shaping.
  5. If necessary, add additional stops or shaping points.
    NOTE: The last stop you add is the route destination.
  6. If necessary, select Route destination list to rearrange the order of stops and shaping points along the route.
  7. After you have finished planning the route, select Save.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
