Handlebar Controller
The Handlebar Controller app allows you to view and configure the actions triggered by each button on the Handlebar Controller accessory.
By default, the handlebar controller buttons trigger the following actions.
Triangle
Short press to save the current location.
Long press to skip the next destination on your route.
Plus Sign
Press to zoom in on the map.
Minus sign
Press to zoom out on the map.
Circle
Short press to change the map type.
Long press to lock or unlock the screen.
In addition to the user-configurable actions, you can press the Plus Sign and Minus sign buttons to interact with on-screen dialogs.
Configuring the Buttons
You can configure each button on the handlebar controller to trigger different actions.
  1. Select Apps icon > Handlebar Controller.
    A diagram of the handlebar controller appears. Each button is linked to a short press action and a long press action.
  2. Select Short Press to choose the action to trigger with a short press of the linked button.
    Some actions, such as zooming in or out on the map, must trigger with both a short press or a long press and will automatically be set for both modes.
  3. Select an action.
  4. Select Back to previous page.
  5. Select Long Press to choose the action to trigger with a long press of the linked button.
  6. Select Back to previous page.
  7. Repeat steps 2 through 6 for each of the buttons.
You can select Menu > Restore to set all the handlebar controller buttons back to their default configuration.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
