Adding Portable Propane Tanks
NOTE: This feature is only available with certain vehicle profiles.
When you add your propane tanks to your vehicle profile, the device avoids routing through areas with propane tank restrictions that may affect your route. The device also alerts you when you approach areas that require you to shut off your propane tanks.
  1. From the vehicle profile, select Propane tank symbol > Add Portable Tank.
  2. Enter the weight of the propane tank, and select Save.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
