Connecting the Device to Your Computer
You can connect the device to your computer using a USB cable.
  1. Plug the small end of the USB cable into the port on the device.
  2. Plug the larger end of the USB cable into a port on your computer.
  3. From your Tread® 2 device, select Tap to Connect to Computer.
  4. When your Tread 2 device prompts you to enter file transfer mode, select Continue.
A picture of your device connected to a computer appears on the device screen.
Depending on your computer operating system, the device appears as either a portable device, a removable drive, or a removable volume.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
