Mounting the Device on a Roll Bar
  1. Using a flat head screwdriver or 9/32 in. (7 mm) nut driver, loosen the bolt 1 on the roll bar mount until the ring separates.
    Roll bar mount connecting to the roll bar with a callout
  2. Place the mount around the roll bar.
  3. Tighten the bolt on the mount until the ring is secure.
  4. Insert the ball on the mount 2 into the double-socket arm 3.
    Device connecting to the roll bar mount with callouts
  5. Tighten the knob 4 slightly.
  6. If necessary, rotate the mount 5 so the Garmin® logo faces up, and adjust the mount for better viewing and operation.
  7. Tighten the knob to secure the mount.
  8. Press the device into the mount until it snaps into place.
  9. Route the power cable along a suitable path in your vehicle, and secure it using the included zip ties.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
