Location Search Results
The location search results appear in a list, with the nearest location at the top. Each numbered location also appears on the map. You can scroll down to view more results.
Location search results list with callouts
1
Select a location to view the option menu.
2 Information
Select to view detailed information about the location.
3Adventurous routing
Select to start navigating using adventurous routing (Adventurous Routing).
4 Go!
Select to start navigating to the location using the default route calculation mode for the current vehicle profile.
5 Crossed out lines
Select to view the search results on the map in full screen.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
