Calibrating Pitch and Roll
You can set the angle of your vehicle to zero at any time.
  1. Park your vehicle on a flat, level surface.
  2. Adjust the position of your device in the mount so you can comfortably view the screen.
  3. Select Apps icon > Pitch and Roll > Calibrate.
The values for pitch and roll reset to 0 degrees.
WARNING
To maintain the best accuracy, you must calibrate pitch and roll each time you reposition your device.
GUID-8C1A9F1D-A749-4151-8B0C-42EEAD6ADB34 v2
January 2026
