Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure you have the HRM-Run™ accessory. Accessories with running dynamics have on the front of the module. Pair the HRM-Run accessory with your Forerunner® 630 device again, according to the instructions. If the running dynamics data display shows only zeros, make sure the heart rate monitor is worn right-side up. NOTE: Ground contact time appears only while running. It is not calculated while walking. Parent Topic: Running Dynamics
Tips for Missing Running Dynamics Data If running dynamics data does not appear, you can try these tips. Make sure you have the HRM-Run™ accessory. Accessories with running dynamics have on the front of the module. Pair the HRM-Run accessory with your Forerunner® 630 device again, according to the instructions. If the running dynamics data display shows only zeros, make sure the heart rate monitor is worn right-side up. NOTE: Ground contact time appears only while running. It is not calculated while walking. Parent Topic: Running DynamicsHomeANT+ SensorsRunning DynamicsTips for Missing Running Dynamics Data
