Navigating Back to Start
At any point during your activity, you can return to your starting location. For example, if you are running in a new city, and you are unsure how to get back to the trail head or hotel, you can navigate back to your starting location.
Select an option:
If the timer is still running, select .
If you stopped the timer and you have not saved your activity, select .
If you stopped the timer and saved your activity, select . The device navigates you to the starting location of the last saved activity.
The compass appears. The arrow points toward your starting point. If the timer is not running, you can start the timer again to prevent the device from timing out to watch mode.
Parent Topic: Navigation
