Playing Audio Alerts During Your Run
Before you can set up audio alerts, you must have a smartphone with the Garmin Connect™ Mobile app paired to your Forerunner® device.
You can set the Garmin Connect Mobile app to play motivational status announcements on your smartphone during the run. Audio alerts include the lap number and lap time, pace or speed, and heart rate data. During an audio alert, the Garmin Connect mobile app mutes the primary audio of the smartphone to play the announcement. Volume levels can be customized on the Garmin Connect Mobile app.
- From the settings in the Garmin Connect Mobile app, select Garmin Devices.
- Select your device.
- If necessary, select Device Settings.
- Select Audio Alerts.
Parent Topic: Pairing Your Smartphone
