Navigating to a Saved Location Before you can navigate to a saved location, your device must locate satellites. Select > Locations > Saved Locations. Select a location. Select Go To. The compass appears. The arrow points toward the saved location. Select to start the timer and record the activity. Parent Topic: Navigation
Navigating to a Saved Location Before you can navigate to a saved location, your device must locate satellites. Select > Locations > Saved Locations. Select a location. Select Go To. The compass appears. The arrow points toward the saved location. Select to start the timer and record the activity. Parent Topic: NavigationHomeNavigationNavigating to a Saved Location
