Setting Walk Break Alerts
Some running programs use timed walking breaks at regular intervals. For example, during a long training run, you can set the device to alert you to run for 4 minutes, and then walk for 1 minute, and repeat. You can use the Auto Lap® feature while using the run/walk alerts.
NOTE: Walk break alerts are available only for running profiles.
  1. Select Menu symbol > Activity Settings > Alerts > Add New.
  2. Select Run/Walk.
  3. Enter a time for the run interval.
  4. Enter a time for the walk interval.
Each time you reach the alert value, a message appears. The device also beeps or vibrates if audible tones are turned on (Setting the Device Sounds).
Copyright © Garmin. All rights reserved.GUID-4F4740A7-5CDF-4039-B709-D6EC27899DC1 v3
