Going for a Run Using a Foot Pod
Before you go for a run, you must pair the foot pod with your Forerunner® device (Pairing ANT+ Sensors).
You can run indoors using a foot pod to record pace, distance, and cadence. You can also run outdoors using a foot pod to record cadence data with your GPS pace and distance.
- Install your foot pod according to the accessory instructions.
- Select the Run Indoor activity profile.
- Go for a run.
Parent Topic: Foot Pod
