Creating a Custom Activity Profile Select > Settings > Activity Profiles > Add New. Select a sport. Select an accent color. Select a profile name or enter a custom name. Duplicate profile names include a number. For example, Run(2). Select an option: Select Use Default to create your custom profile starting from the system default settings. Select a copy of an existing profile to create your custom profile starting from one of your saved profiles. Select an option: Select Edit Settings to customize specific profile settings. Select Done to save and use the custom profile. The new profile becomes the active profile. Parent Topic: Activity Profiles
Creating a Custom Activity Profile Select > Settings > Activity Profiles > Add New. Select a sport. Select an accent color. Select a profile name or enter a custom name. Duplicate profile names include a number. For example, Run(2). Select an option: Select Use Default to create your custom profile starting from the system default settings. Select a copy of an existing profile to create your custom profile starting from one of your saved profiles. Select an option: Select Edit Settings to customize specific profile settings. Select Done to save and use the custom profile. The new profile becomes the active profile. Parent Topic: Activity ProfilesHomeCustomizing Your DeviceActivity ProfilesCreating a Custom Activity Profile
