Data Fields
Some data fields require ANT‍+® accessories to display data.
%HRR
The percentage of heart rate reserve (maximum heart rate minus resting heart rate).
24-Hour Max.
The maximum temperature recorded in the last 24 hours.
24-Hour Min.
The minimum temperature recorded in the last 24 hours.
Average %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current activity.
Average Cadence
Cycling. The average cadence for the current activity.
Average Cadence
Running. The average cadence for the current activity.
Average HR
The average heart rate for the current activity.
Average HR %Max.
The average percentage of maximum heart rate for the current activity.
Average Lap Time
The average lap time for the current activity.
Average Pace
The average pace for the current activity.
Average Speed
The average speed for the current activity.
Avg. GCT Bal.
The average ground contact time balance for the current session.
Avg. Ground Contact Time
The average amount of ground contact time for the current activity.
Avg. Stride Len.
The average stride length for the current session.
Avg. Vert. Ratio
The average ratio of vertical oscillation to stride length for the current session.
Avg. Vertical Oscillation
The average amount of vertical oscillation for the current activity.
Cadence
Cycling. The number of revolutions of the crank arm. Your device must be connected to a cadence accessory for this data to appear.
Cadence
Running. The steps per minute (right and left).
Calories
The amount of total calories burned.
Distance
The distance traveled for the current track or activity.
Elapsed Time
The total time recorded. For example, if you start the timer and run for 10 minutes, then stop the timer for 5 minutes, then start the timer and run for 20 minutes, your elapsed time is 35 minutes.
Elevation
The altitude of your current location above or below sea level.
GCT Balance
The left/right balance of ground contact time while running.
Ground Contact Time
The amount of time in each step that you spend on the ground while running, measured in milliseconds. Ground contact time is not calculated while walking.
Heading
The direction you are moving.
Heart Rate
Your heart rate in beats per minute (bpm). Your device must be connected to a compatible heart rate monitor.
HR %Max.
The percentage of maximum heart rate.
HR Zone
The current range of your heart rate (1 to 5). The default zones are based on your user profile and maximum heart rate (220 minus your age).
Lap %HRR
The average percentage of heart rate reserve (maximum heart rate minus resting heart rate) for the current lap.
Lap Cadence
Cycling. The average cadence for the current lap.
Lap Cadence
Running. The average cadence for the current lap.
Lap Distance
The distance traveled for the current lap.
Lap GCT Bal.
The average ground contact time balance for the current lap.
Lap Ground Contact Time
The average amount of ground contact time for the current lap.
Lap HR
The average heart rate for the current lap.
Lap HR %Max.
The average percentage of maximum heart rate for the current lap.
Lap Pace
The average pace for the current lap.
Laps
The number of laps completed for the current activity.
Lap Speed
The average speed for the current lap.
Lap Stride Len.
The average stride length for the current lap.
Lap Time
The stopwatch time for the current lap.
Lap Vert. Ratio
The average ratio of vertical oscillation to stride length for the current lap.
Lap Vertical Oscillation
The average amount of vertical oscillation for the current lap.
Last Lap Cadence
Cycling. The average cadence for the last completed lap.
Last Lap Cadence
Running. The average cadence for the last completed lap.
Last Lap Distance
The distance traveled for the last completed lap.
Last Lap Pace
The average pace for the last completed lap.
Last Lap Speed
The average speed for the last completed lap.
Last Lap Time
The stopwatch time for the last completed lap.
Maximum Speed
The top speed for the current activity.
Pace
The current pace.
Performance Condition
The performance condition score is a real-time assessment of your ability to perform.
Speed
The current rate of travel.
Stride Length
The length of your stride from one footfall to the next, measured in meters.
Sunrise
The time of sunrise based on your GPS position.
Sunset
The time of sunset based on your GPS position.
Temperature
The temperature of the air. Your body temperature affects the temperature sensor.
Time in Zone
The time elapsed in each heart rate or power zone.
Time of Day
The time of day based on your current location and time settings (format, time zone, daylight saving time).
Timer
The stopwatch time for the current activity.
Training Effect
The current impact (1.0 to 5.0) on your aerobic fitness.
The amount of bounce while you are running. The vertical motion of your torso, measured in centimeters for each step.
Vertical Ratio
The ratio of vertical oscillation to stride length.
Copyright © Garmin. All rights reserved.GUID-4F4740A7-5CDF-4039-B709-D6EC27899DC1 v3
