You can navigate back to the starting point of a saved activity in a straight line or along the path you traveled. This feature is available only for activities that use GPS.
Select
Select an activity.
Select
Turn-by-turn directions help you navigate to the starting point of your last saved activity if you have a supported map or are using direct routing. A line appears on the map from your current location to the starting point of the last saved activity if you are not using direct routing.
NOTE:
You can start the timer to prevent the device from timing out to watch mode.
Select
DOWN to view the compass (optional).
The arrow points toward your starting point.
