Customizing the Widget Loop
You can change the order of widgets in the widget loop, remove widgets, and add new widgets.
  1. Select Menu symbol > System > Widget Management.
  2. Select a widget to add or remove it from the widget loop.
  3. Select Rearrange the menu symbol to change the location of a widget in the widget loop.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
