Using Electronic Shifters
Before you can use compatible electronic shifters, such as Shimano® Di2™ shifters, you must pair them with your device (Pairing Your Wireless Sensors). You can customize the optional data fields (Adding a Data Screen). The Edge® 830 device displays current adjustment values when the sensor is in adjustment mode.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
