Pairing Your Wireless Sensors
Before you can pair, you must put on the heart rate monitor or install the sensor.
Pairing is the connecting of ANT‍+® or Bluetooth® wireless sensors, for example, connecting a heart rate monitor with your Garmin® device.
  1. Bring the device within 3 m (10 ft.) of the sensor.
    NOTE: Stay 10 m (33 ft.) away from other riders' sensors while pairing.
  2. Select Menu symbol > Sensors > Add Sensor.
  3. Select an option:
    • Select a sensor type.
    • Select Search All to search for all nearby sensors.
    A list of available sensors appears.
  4. Select one or more sensors to pair with your device.
  5. Select Add.
    When the sensor is paired with your device, the sensor status is Connected. You can customize a data field to display sensor data.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
