Selecting an Activity for Route Calculation You can set the device to calculate the route based on activity type. Select > Activity Profiles. Select a profile. Select Navigation > Routing > Routing Mode. Select an option to calculate your route. For example, you can select Road Cycling for on-road navigation or Mountain Biking for off-road navigation. Parent Topic: Route Settings
Selecting an Activity for Route Calculation You can set the device to calculate the route based on activity type. Select > Activity Profiles. Select a profile. Select Navigation > Routing > Routing Mode. Select an option to calculate your route. For example, you can select Road Cycling for on-road navigation or Mountain Biking for off-road navigation. Parent Topic: Route SettingsHomeNavigationRoute SettingsSelecting an Activity for Route Calculation
