Transferring Files to Another Edge Device
You can transfer courses, segments, and workouts wirelessly from one compatible Edge® device to another using Bluetooth® technology.
  1. Turn on both Edge devices, and bring them within range (3 m) of each other.
  2. From the device that contains the files, select Menu symbol > Connected Features > Device Transfers > Share Files.
    NOTE: The Device Transfers menu may be in a different location for other Edge devices.
  3. Select a file type to share.
  4. Select one or more files to transfer.
  5. From the device that receives the files, select Menu symbol > Connected Features > Device Transfers.
  6. Select a nearby connection.
  7. Select one or more files to receive.
A message appears on both devices after the file transfer is complete.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
