Getting Your Training Load Estimate
Before you can view your training load estimate, you must put on the heart rate monitor, install the power meter, and pair them with your device (Pairing Your Wireless Sensors). If your device was packaged with a heart rate monitor, the device and sensor are already paired. For the most accurate estimate, complete the user profile setup (Setting Up Your User Profile), and set your maximum heart rate (Setting Your Heart Rate Zones).
NOTE: The estimate may seem inaccurate at first. The device requires a few rides to learn about your cycling performance.
  1. Ride at least once during a seven day period.
  2. Select Menu symbol > My Stats > Training Status > Load.
    Your training load estimate appears as a number and position on the color gauge.
    Training load data
    Red Red
    High
    Green Green
    Optimal
    Blue Blue
    Low
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
