Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride. At any time, swipe down from the top of the screen, and on the controls widget, select Back to Start. Select Along Same Route or Most Direct Route. Select Ride. The device navigates you back to the starting point of your ride. Parent Topic: Locations
Navigating Back to Start At any point during your ride, you can return to the starting point. Go for a ride. At any time, swipe down from the top of the screen, and on the controls widget, select Back to Start. Select Along Same Route or Most Direct Route. Select Ride. The device navigates you back to the starting point of your ride. Parent Topic: LocationsHomeNavigationLocationsNavigating Back to Start
