Deleting Files
NOTICE
If you do not know the purpose of a file, do not delete it. Your device memory contains important system files that should not be deleted.
  1. Open the Garmin drive or volume.
  2. If necessary, open a folder or volume.
  3. Select a file.
  4. Press the Delete key on your keyboard.
    NOTE: If you are using an Apple® computer, you must empty the Trash folder to completely remove the files.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
