Map Themes
You can change the map theme to adjust the appearance of the map for your ride type.
Select Menu symbol > Activity Profiles, select a profile, and select Navigation > Map > Map Theme.
Classic
Uses the classic Edge® map color scheme, with no additional theme applied.
High Contrast
Sets the map to display data with higher contrast, for better visibility in challenging environments.
Mountain Biking
Sets the map to optimize trail data in mountain biking mode.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
