Planning and Riding a Course
You can create and ride a custom course. A course is a sequence of waypoints or locations that leads you to your final destination.
  1. Select Navigation > Courses > Course Creator > Add First Location.
  2. Select an option:
    • To select your current location on the map, select Current Location.
    • To select a saved location, select Saved, and select a location.
    • To select a location for which you recently searched, select Recent Finds, and select a location.
    • To select a location on the map, select Use Map, and select a location.
    • To browse for and select a point of interest, select POI Categories, and select a nearby point of interest.
    • To select a city, select Cities, and select a nearby city.
    • To select an address, select Addresses, and enter the address.
    • To select an intersection, select Intersections, and enter the street names.
    • To use coordinates, select Coordinates, and enter the coordinates.
  3. Select Use.
    TIP: From the map, you can select another location, and select Use to continue adding locations.
  4. Select Add Next Location.
  5. Repeat steps 2 through 4 until you have selected all locations for the route.
  6. Select View Map.
    The device calculates your route, and a map of the route appears.
    TIP: You can select Elevation symbol to view an elevation plot of the route.
  7. Select Ride.
Copyright © Garmin. All rights reserved.GUID-E907C1CF-6838-46D3-9F29-C1522BCEA3BC v7
